I used Jiff :P on my GTR last night to remove a sticker off the rear bar!
It worked quite well suprisingly. I've had this stupid sticker on there since I imported the car. It was literally randomly placed on the rear bar. Why they stuck it there, I will never know.
Jiff ftw!!
I'm sick of my GTS-T already. :P
I'm not.. 7 going on 8years strong. :P
The R32's are great fun little cars; I've driven r33's just not for me too boaty less racy feeling; R34's yeah felt really nice with that r32 racy/feedback feel.
Hahaha Joel if R33's are boaty you should try mine for a luxory cruiser its not too bad :P
im going to ring Shaun and see how much for a touch up tune i reckon since putting the pfc in it may have picked up a few more angry wasps :P
uuuuummmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm possibly, i can't remember lol. i don't think so?
i saw a nice 34 there, thought it might ahve been yours. although it didnt have to white lids on the head lights so i wasnt sure :S
Jiff ftw!!
K @ H wax and grease remover is also great for that kind of thing! highly recomend it.
I was wondering what was good to use on those types of things! I had some of that Turtle bug, small baby and tar removal stuff that you can spray onto your car, but it didn't work
hey boys and girls...
REALLY NEED a r32 MSPEC front bar!!!!
and REO BAR!
I had a good look at my reo and turns out it has been trimmed to fit a cooler, it's only a small section so I didn't notice it before.
There's not much metal missing at all, but if you want something un molestered for regency I'm afraid mine probably won't do. :D
Edited by AndrewJZX100
its been 2 weeks since i last drove my car, so i just took it out for a lap of the block, it just doesnt feel right
maybe its angry at me? lol
any one else felt this after not driving it for a while?
every car feels like a commodore if the setup is wrong....
my 33 has HR tien coilovers, decent tread on 18's and gay strut braces and already has amazing turn in, and yes ive driven all sorts of cars to compare...Very happy the way the thing handles. Flat as and turn in like a mofo. Let the talking happen in the hills.
Edited by Ryanrb25
When i had the corolla id leave the 33 there for a week or two then jump in it and it would remind me why i still got it, felt f*kn amazing in comparison to the corolla haha.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
