Haha this is getting a bit personal. :domokun: lol
Well we all know who rates higher.....seeming as you aren't coming on my cruise and all! :devil:
Anyways, tis my bedtime. I feel crappy...this didn't help :cool: *tear*
:domokun::domokun:
Well we all know who rates higher.....seeming as you aren't coming on my cruise and all! :cool:
Anyways, tis my bedtime. I feel crappy...this didn't help :( *tear*
:devil::domokun:
Everybody hug Charmaine :domokun:
how much would a ca18 motor cost, coz i need to get 1 from somewhere
About $1800 from an importer (low kms). I picked up mine, complete engine less turbo for $500 from a private seller years ago!
Are we talking DET or DE, FWD or RWD? Shaun from Boostworx might assist locating one. I know Craig (when he ran Maddat) did a few SR and VG swaps replacing CAs when he shared Shaun's shop.
:domokun:
Edited by RubyRS4
lol that emote says
"everyone molest Charmaine"
"hug" or "molest" ... same thing really depending on who's giving and who's receiving! :domokun:
Learnt that in catholic school :domokun:
:domokun:
hmm apparently i need a ca20e not a ca18
much cost difference do you think??
i can't afford $1800 :domokun:
any1 interested in giving me charity?? :domokun:
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
