For Rad33 with his new rb25det on the way.. Get an rb30 under it. :D
RB25det vct head FTW for bottom end. :D
AL's motor is running the same GT3076 .82 on an rb30det but with a nice exhaust and inlet manifold with slightly smaller cams. The VCT has picked up some nice low end power peak power appears to be made around 7000rpm.
Now for mine.. :) 15.5psi that can be seen and the last tune at 19.5psi through the mid that tails off to 17psi causing top end to flatten out. The 2" fmic piping is causing issues up top as well as the wastegate flap being blown open.
Mine makes its peak around 6000rpm. Will play with the adj. cam gears to shift that to approx 6500rpm. :D
joel... its rad32 now hahaha...
and yeh im gonna go the 30 bottom once the 25 goes in and is road regestered! :D
how can i get the engine home?? and will i need a engine crane to load it on the trailer as the gearbox is still attached!
So when the mechanics drive my car it doesnt shit itself?????????? FFS!
so where does that leave me? high and dry.
the only thing i can do is.... what for it to happen again and make sure it happens at the mechanics?
ill have to try and clean out the AFMs and check for damage.
Adrian they could fit in the back of a ute just hire one and get Adam and the purple chickens to help you lol :D
Also anyone going to pop down to villi's my phone is flat so you cant ring
also please dont talk about molesting like its a joke! :)
yeah i recon you will but i could see if we can borrow one
and i know that the dinner is one but for people that arent going and for after if im not there ill be at home and i told damo if you guys want to come over if im not at villi's you can :D
I had the same problem and it was solved by replacing one of my AFM's. I have a spare rb26dett stock AFM, if you need to borrow it to see if it makes a difference, just send me a PM
-D
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
