is it hard to remove the injectors and resistor pack?
If they're anything like an SR then nah, I swapped mine over pretty easy (save for destroying the old ones :huh: those O rings had a damn good seal on them :D)
Norman: Is that the one with all the hairpins that comes out near the wreckers on the corner?
Edited by AndrewJZX100
yeah just watch out with the injectors hey, mine were all brittle and didn't take kindly to being manhandled with a pair of pliers :huh: Pop the seal on the O ring first and you should be right.
ECU I doubt it, as the resistance would probably be different (this being the only reason you'd put a Z32 meter on a 20 as they already have 80mm meters if I remember correctly :D)
ok sweet... is tomorrow still fine for the reo?
and im gonna de jetro my stock ecu hahahahaha... save re wiring the afm back in LOL... j.k
z32 went on coz my stock one was maxing at 190kw
Edited by rad32
Yeah mate tomorrow is all go, about 4:15 as previously noted. You should be able to just wait near the boom gates if I'm not there but I'll endevour to be earlier so you don't have to wait around.
Thats weird about the AFM, I was under the impression they flowed well and only really need changing when going for big power as the tuning resolution is a better with a Z32 item. Mine's only running about 180@wheels anyway, and I need to get the sus/chassis sorted before I need anymore :huh:
^ those unfortunately I do not have. I reckon a hardware store would have the required bolts though.
And while we're linking random youtube vids, I fking love this thing, such an angry sounding car :huh:
http://www.youtube.com/watch?v=qS_huNoq5SU
hmmm shit I'm hungry, why can't there be 24 hr delis where I can go get a pasty with sauce or some chips and gravy at like 1am :huh:
Vilis is one option but I'm not keen on driving 45 minutes to go there :D
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
