OK so raising money....
Damo is making the fairy bread.
And Nene the cupcakes.
:blink:
What a team lol
Now that im home from school i can access zoo weekly :P Time to vote lol
haha, you just wanna check out the chicks, dont lie :huh:
Adrian and Scotty know im a huge fan of cold sandwich steak smothered in butter, with crushed nacho cheese doritos and tomoato sauce. mmmmmm, now thats tasty
Hey Nene, do you and Ben know Damo (matt black CBR)? He dropped in this morning on the way to work. He's cold his CBR1000RR and has bought an R33 Skyline!
I think he was once goin to buy my RS4 until I told him Simo is buying it :blink: We can forgive him for buying a Skyline and not a Stagea? :P
Edited by RubyRS4
ahhh its done! :huh:
started polishing the 33 yesterday, after debating whether to do it myself, or pay cargroomers 120 bucks to do it.
it cost me 120 bucks in materials, but atleast i can say i did it.
i used meguires crystal polish, twice on each panel
then meguires next gen. tech wax @ 50 bucks a pop!
but f**k me dead, its good shit!
i took my time and did it over two days, and the result is awesome! a deep glossy black whale with wheels :blink:
ready when you are for pics charmaine :P
haha yeah we can forgive him for that... i don't think i know him.. ben might?? why is that roo?
yeah well guess what i just made myself... FAIRY BREAD! AND ITS GOOD! :blink:
Did you make me any? :P
And craig....pics...well. when are you free lol
I wouldve said this weekend, as i started off having nothing to do...but its sort of been filled now lol
Actually. I could probably squeeze you into my schedule on Sunday :P
Gimme a time and a place and i'll be there....although the place may have to be negotiable seeming as i live on the other side of the world to you :blink: lol
:laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
i need to get some paint touched up then a nice polish all round :P
He rides with the boys often. I'm sure he was out with us one night when you and Ben first got the 260 back. Don't recall you guys talking to him like you do with the others.
Anyways ... he's sold his bike and bought an R33! :P:blink:
out of random....
hell pised off this weekend...my car was parked out the front of my girlfriends house all weekend...(not a bad suburb or anything) and got in it sunday arvo only to find that some little vandal put a ball bearing through it,,,, and its all broken and shattered....still intact...only by my duct tape.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
