the nissan coolant is about $12 a litre and it is pure concentrate, the guy at nissan said it takes about 3 litres to do most cars but obviusly buying 5 litres for $50 works out cheaper and because its a 30/ 70 blend, 2.5 liters with the rest just water will be fine:) Ryan and i went halves and havent looked back. both our 33's run cool:) Nissan genuine coolant FTMFW!!!! :rofl:
yeah, but pure concentrate what??
see if you can find out what it consists of and what percentage.
what style catch can you go with? i got the smaller greddy 1, finding hose and fitting it is quite annoying. there are like a million ways to do the plumbing....
what turbos you got? 2530s yeh? after i sell my other skyrine im going to look into getting new turbos.... not sure what to run? GT-SSs, GT2860s or 2530s...
i spoke to a midwife today, told her about him wanting her to go and she told that i make all the decisions
coz it's my body and i'm the 1 having it. they've reffered me to a social worker there and my doctor is
reffering me to a psycologist (free thank god) and she put me back on meds.
the doctor did my blood pressure, she was surprised that it was normal haha, but like i told her i'm only really
angry when i told to him and after that i'm not so bad.
she also asked me if i've been crying alot, told her i only had a bit of a cry the other night, but i've been
wanting to cry so bad, i just don't want to coz if i start i won't stop haha
ahh thank god for you people on SAU :bunny::banana::rofl:
Edited by pokie
how much do those turbos go for these days? +dumps +fronts as well yeh? did you get a highflow manifold as well?
turbo upgrades cost so much lol. so worth it tho :rofl:
regarding the catch can - the 2 top nipples on the rocket covers, in pics ive seen it looks like people have turned them to face each other??? any1 know how to do that? maybe im not awesome enough
here is a lame pic of it lol
helloooo! my first post in like 3 weeks. woooo! ok ideas are needed. went to survice my vl (rb20det) and oil filter wont come off.. tried everytihng including the old stick a large screwdriver through it and turn but it ended up cutting it round like a can opener. its pretty mangled and i was wondering if anyone had any special techniques?? i dont wanna take the inlet manifold off but im starting to think i might have to. grrr any help or ideas would be much appreciated. steam gun on the thread? and a pipe wrench? hahaha
hey babe how are you
try some hot water and a filter remover?
ahh thank god for you people on SAU :D:):rofl:
not to stir the boat, but it takes 2 to tango.....it may be your body but you should take into consideration your boyfriend/ex boyfriends sittuation....
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
