hey Chad if you're serious we should go and see him together.....might get a better price for a couple of sets.
yeah, im serious. i want some new pipes before the turbos go on, im still pretty keen for those Greddy ones, just depends on the cost difference.
well i just need ones to suit 32, i have 34 front pipes now, so i'll have to modify my exhaust back to 32 specs. which should give me more ground clearance i hope.
Also dropped off my 34 gtr rims today to get painted, think im gonna get them painted the same colour as my Drift Teks.
so, got bored at about midnight, so i decided id take advantage of the half not shit weather and go out and get some pics of my car. found a pretty good spot out in port adelaide, and i stole petes spot in reynella :O, pretty cool for a church, lol.
shame the camera was acting pretty freakin weird for the last couple hours :P
we should probably just rig the lotto.
takes care of that 'work' issue.
that being said, i could go out, get myself a gambling addiction, have myself self-barred from all gaming lounges in sa, then claim work cover cause of my temptation to gamble while im at work :O
... yeah, rigging the lotto is a better idea...
is it the whole kit globes and igniters, becuase HID globes are different to halogen globes :O
Lol Steve of course it is the whole kit. however, i did buy globes to suit an R34 from 666DAN, then realised i didnt have factory HID installed, then i bought a HID kit to suit R34 minus globes.
666DAN
Yeah....666Dan, his kits are tops... make sure u specify if u need the aircon leds in addition to cluster/gauges...
also, i got an entire set of red ones that I took out to put blues in if anyone wants em
-D
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
