i just got the slotted all round, with QFM pads that steve organised for me,
pedal feel is great! stops much harder thats for sure.
i reccommend them, come round, ill let you take it for a lap.
had the same thing happen like 4 houses done from my place around 5months ago. There was a drug lab, cops raided the house pulled out so many plants. I didnt even know the house was holding anything. Apparently the house was under surveillance for some time. Good fun to watch tho.
I'm live near tattoo this... so I see a bit of finks action from time to time.
I must say the have fkt buisness for the seacliff pub (it's a hole and over priced ne way... still a bummer it's the closest pub to my house)
