Pretty sure its 10 working days (2 weeks) and the say they will call you, but I called up at about 8 working days and they told me they were ready - so best to call towards the end of the 10 day period.
hey steve, your HID's, were they hard to wire in?
+1. i have my kit sitting here, the kit is to suit R34, and the 6000k HID globes are to suit R34 (H2C) type globes, but the ballast plugs dont match the HID plug at all. Id imagine that if the ballast plugs plugged directly into tho HID bulbs, its easy as piss.
yeah, i just ordered a set of 5000k H4 from a 31 club group buy, figured id do my installation homework now though :P
if it involves wiring, ill get it eventually, but shit, it has me running for the hills at the start..
how long does it take for custome plates to be made?
and will they call me when they ready for pick up?
Each time I ordered custom or R series plates I had to chase them up, I never got no call telling me they were ready. :P
thanks mate, i hope they look good.
na dont worry about it just yet mate,
im getting lowered springs this weekend, 4 spacers from wheel worx and my guards rolled
plus fathers day pressies, all in a mortage week, im pretty tight mate lol
thanks though! maybe next weekend?
heres a nice example, and fairly cheap for what it is. V Spec II NUR, 4000k's, passenger seat and rear seat still in plastic.
http://www.j-spec.com.au/list/index.php?ID=13486
R32 GTS-t Type M Tommy Kaira http://www.j-spec.com.au/list/index.php?ID=13475
99 Nissan Gloria http://www.j-spec.com.au/list/index.php?ID=13471
and a pretty awesome (but standard) GT-T http://www.j-spec.com.au/list/index.php?ID=13468
mmm I dig the Gloria
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
