the trust ones that jenkies is interested in. If they are similar to the N1 , id say they are fairly responsive, similar to a stock turbo, but build alot stronger so they can handle more boost.
i tried the search function but got nuthin :banana:
so ima ask it here, whats the widest wheel you can get on a 32 gtr? and the ofset you need to acheive this?? guessing around the 10-11 mark?? would be for a 18 inch wheel aswell
10inch wide with a +18 offset....
just wondering if anyone knew much about greddy t517z x2 suit gtr. power potential, posatives and negatives
cheers in advance
hey mark, where ya been bud?
I'm no expert on these snails but I think you may find they have journal style bearings as opposed to the Garrett style ball bearing
carl, what did you use for your glovebox setup? (materials)
its a piece of black plastic that is about 4mm thick that has been cut as a facade, and have put a couple gauges in there... used to have ebc inthere too, but i choose to abide the law nao :laugh:
i'll prolly be at villis if u wanna see it, im planning on re-doing it soon
I've been doing a fair bit of research on new snails...
t517z x2: Beware theres 2 types of housings, an 8cm and 10cm one. 8cm is equivilent to GT5860-7(HKS GTSS), 10's = GT5680-5(HKS GTRS) and SLED is correct that they aren't Ball Bearing. From what I've heard quite linear quite peaky compared to the Garrets.
The -5 is bigger than the -7 if that makes any sense.
Some specs here: Gtr twin turbo comparisons
I've settled for a set of 34N1's because they're supposed to be similar to stock response.
so that would be bout a 275ish???
i got 275s on mine dont ask me what rim size n offset though dont know. tires start getting pretty expensive at that size by the way :)
ur welcome to have a look when i get it going again.
Edited by Inline 6
my neighbours are sooooooo annoying, there over here all the time.
1 of them (Samantha i think) was talking to my mum yesterday and said she thinks she knows
me, so my mum and dad hounded me to go talk to her (i didn't), she left eventually.
yeah i'm not a very social person when it comes to neighbours haha, i know no1 on
my street and i'd like to keep it that way :)
HELP please!! Just after ideas atm on what it could be but when i take my foot of the accelerator i get a clunking noise sounding like its coming from either my dif! Its now also sounding like the back end is almost bouncing while driving. How do i check to see what it is and advice please??? :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
