I don't think Kellie is in the mood to be helping people for a while. Perhaps give her a break and allow her to volunteer to assist. :)
kell actually spoke to me on the phone this arvo,
but thanks for your input ruby.
fishpaste~ and i were behind you, must have missed you on the side of the road (dont know how :P ) could have got a tow rope, and taken you back to your place water ski style :)
Yeah, we got WAY behind you at south rd/anzac highway intersection... can't quite weave threw cars like you can =P
We could see you up ahead, but I though you had safely turned down daws road, and we continued down south road... probably should have swapped phone #'s
ahh, thanks boys. I wanted to get home quickly while it was running fine but like I said, she broke down just outside the Tonsley Pub and I ended up rolling into Lloyd St, St Marys to avoid sitting on the main road for the next hour........I was only 1 km from home so a tow at 10kph might have been a good idea. Now I just have to go thru the threads to find a good mobile auto electrician cause I'm over working on it.
hey Pete would you be able to take a photo of your brake master cylinder on the GTR and post it up?
Just need to have a look at it before i put mine in.
Thanks Luke
OK Luke sorry it's taken so long but here goes.....the blue bracket is the support for anti flex.
EDIT: Thanks Carl
had a dinner party last nite at my place, it was great.
we supplied pizza bases, cheese, shredded ham sauces etc, and then got ppl to bring along other ingredients... easilly fed 19 ppl, and had some good times
had all sorts of gourmet stuff... the best pizza i made had satay sauce, chicken, onion, camenbert, and mango :)
Hi everyone, i was just browsing as usual.. and came across this thread that i thought might help you prevent theft in case you missed it.
http://www.skylinesaustralia.com/forums/An...ft-t231396.html
scroll down to the posts "waza" makes and there is a lock that prevents people from shifting gears when the car is unattended to.
I thought this might be useful for everyone that is paranoid about their cars being stolen.
Edited by TS-R34
just sold 2 of my 25mm spacers :)
will be going to wheel worx tomoz to pick some more up
not sure whether to go 15 or 20 :P
measure the point of the tyre that stands out the most to the top of the gaurd. will give you the best idea if you didnt want to drive the car to them.
or just do what i do and ask joe to let you test fit or ask for advise. dont want to end up were you were before :P
yeah, im gonna take the 25s off, and drive it down to wheelworx on saturday now,
ill ask for a test fit on the 15,
i want them to look good, but not rub, i want the best of both worlds :)
should have called you to meet up for entry forms today kye.... i was down at my auntys holiday house in aldinga
:P and i was home most of the day too. its sitting in the boot of my car so ill hook you up before friday.
flat tyre and no tyre shops open on a sunday is gayness. i dont trust those space savers!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
