i see you found its good side to take a pic of.
i didnt realize it had a good side..
You are wrong, it has a shit side and a not so shit side :)
There are a few more pics in my members ride thing, showing how fecked the rear is :)
has anyone here had to have their turbo seals fixed??? if so was it expensive and did it take long to get done??? i couldn't find any info using search so i just asking a general question.
Still running the ceramics? Once you get a price, let me know, too. One of my seals is on the way out, spitting out oil, etc and I'm still running those lovely ceramics!
alright i'll let ya know.. im hoping it's not too much
Turns out my turbo may not be f**ked after all, had a mad mad leak on one side of the manifold because it warped. Turbo feels brand new still and im still gonna get it sussed out by mtq just for curiosity's sake. Im not putting it back on tho...time for an upgrade :D
Edited by Ryanrb25
just watching it as i write this, saw a grey 32 gtr get pulled over for no rear lights, he hell cut sick and said, whatta bout all those rusty shit boxes you dont pull over! cops were fair decent about it in my eyes, he got defected, but in the end a police escort home, and them not charging him for speeding was decent of them! he had 2 weeks to fix the defects! just thought i would share this pointless info to the rest of sau, incase anyone else saw this! imbored yes
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
