its funny how bad ideas somehow seem good when youre half cut. :)
oh yeah, dtei has 'transport compliance' patrol cars running around, anyone know what the deal is with those?
if no-one has posted about this, they're the guys that run the inspection stations out on the side of the highways, plus they also have rights to pull over and issue defects to heavy vehicles and taxis
these pricks were running round town one night, they'd finish with one cab, bolt round the corner, throw on the purple lights and do another one :)
and on another note, my internet speed :rofl: - bigpond cable internet (same cable as foxtel uses :))
same got a small cold which is just about gone.
YAY i just rid of mine!
Been hit hard by the flu. Doesn't help working 10 hours yesterday. Moved up to an inner ear infection aswell.. So I'm suffering abit. But the girlfriends looking after me :P
