hey people i need some stockies asap. a full set to borrow for a week or so.
ill pay in cash, booze or sexual favors !!!
I've got stockies if you've got a 5 stud conversion on that 32.
:P
Because she's nice ... and she has boobs ... unlike you! :)
i thought becuase she has boobs that you would want to wash her car :P
Hey!! can we lwave my boobs out of the convo!!
I can take a joke as much as the next person, but thats my wife your talking about and im failing to see the humour in it right now. :P
i thought becuase she has boobs that you would want to wash her car :)
lol, you guys....pull your heads in......it's no wonder why my wife doesn't get involved with this forum
sooooooooooo yesterday i was told by the father to be that he hates me
because i'm pregnant.when he said that to me i just said "well then you should
hate yourself aswel coz you helped"
went to the show yesterday, i had plans to get the Little Miss showbag, until i saw it
the bag was so small and the slippers in it well lol, i would have no hope with getting
my feet in them. :)
I can take a joke as much as the next person, but thats my wife your talking about and im failing to see the humour in it right now. :)
sorry Ben was all in good Fun, didn't see that i may upset you certainly wouldn't make fun of someone's wife on purpose
my feet in them. :)
yeah show bags suck now there not like they were when i was a kid the bags were big and fill with heaps of crap you didnt need now there is 1 piece of crap and not much else
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
