got a pic n how much dude?
like this one here mate, ill sell it for $20
http://cgi.ebay.com/ebaymotors/Nismo-Leath...sspagenameZWD2V
ive still got the stock knob out of my 180, i kept it when i got rid of the 180. i love the feel of it, and have never felt one that feels as good.
too much info ted :O
Edited by Sambo33
hey man link doesnt work says item has ended or been removed
you need to re-install all your programs flick =(
you can copy files, but not the programs... despite what ted says
i disagree whilst some programs WILL need a proper installation a lot wont and if you want to take it to a smarty pants on the forum you can copy registry keys and load the keys up after dragging and dropping the only problem you will/may face is if the said program installs .dll's into windows directory but you would usually get a error about what file is missing :)
lol steve...
who thinks 13 is fair?
with all the goodies of course
sounds ok man got a few goodies :D gl with sale
300++ here you come.
Have you got internals done or you looking to find what the stockies can take first?
lol nah, gonna run max 1.1bar through stocky motor until i get it built hopefully once funds permit. Should still be lookin at around 260-270rwkw...Im actually looking forwards to less response more traction.
So i may need some help with this then. Re-installed my photoshop, but dont have my original serial number. Would like to copy it over to the new computer, as it has a few batches/scripts set up, that i dont know how to redo, as someone done them for me. Was hoping to copy the programme straight over so i could keep these scripts.. if that makes any sense
i take it the computer there coming from is a desktop ie unmovable easily
Both laptops.. Ill bring them both to Lukes saturday night (if i havent sorted it out by then). Few people that are going including u, might be able to help me with it
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
