bahaha, yeah, that was me, first time i was cruising out to my sisters place, second time ben said he saw me so i figured out cruise back and see where he works, last time i was just bored. :)
I'd sell my 33 to get a house tomorrow but i kno no one would buy it for the money i'd want so might as well keep it and get my money's worth.
i agree with u Ryan, c u 2moz.........
buy my old turbo craig and bolt that on, then you'll wanna keep it
or how bout u Adrian....??????
i no u guys want 2...lol
haha next time do a skid! car sounds great man.
someone needs to! Will be a weapon.
sms me when your home mate, ill pop round...Ill be at adrians earlier.
Edited by Ryanrb25
yeah... i aint too keen on treatin my car like shit yet. give her a bit of lovin in the form of a good servicing next week, and if that doesnt work, well, mechanical sympathy will probably go out the window...
... unless i think of something that doesnt involve treating my car like crap. :)
truer words have not been spoken in this thread
I have to go in there tomorrow after work to get a new gasket for my new turbo anyway, so ill grab two and also belts for a 100thou service i have on sat. Ill let you know how much it costs bro.
can we catch up tomorrow for that loom and sensor
Anyone know where Jasmin restaurant is? I know it's in hindmarsh square but like where abouts? Probably gonna go there for dinner tonight and don't wanna be struttin around hindmarsh square lookin for it :)
Come to the Flying Knife at semaphore. I'll be working tonight.
The Flying Knife
Its next to where sprouts used to be (if you know them).... on the north western side of Hindmarsh, in a basement area. Near the Internode building.
I went there 4 weeks ago. Probably the best indian food in Adelaide, and I've had them all.... +1
-D
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
