i used to work in a few gaming rooms round adel.
and i felt really sick, when i see people back and fourth to the atm
withdrawing 100+ bucks at a time.
and loosing it in a matter of minutes.
and those dumb feckwitts who think there is an ''art'' to playing them and certain ways
you can win IE: rubbing the symbols.
i seriously dont get it.
try being a dealer.
same deal, but people coming back to tables with thousands and losing it all in a matter of minutes.
as for the 'art' of playing, again, try being a dealer, some of the shit you see is as astounding as it is downright confusing.
been doing it close to 2 years, and some of the shit they say and do still catches me off gaurd.
whenever i have a splash on the pokies ill use like 5 bucks maximum, and whenever i win more then a dollar ill take it out, sometimes i put 5 dollars in and come out with 7!
haha, good way to play. stick to a maximum. or f**k it all off and buy another beer. at least you have something tangible then.
:bunny: i find it hilarious that the father of a no pokies campaginer spends most of his time in the grange room
I have watched a mate say he can control himself and make regular trips to the atm, not cool.
yeah, nick is no pokies. emphasis. he has nothing against actual gaming, just against pokie machines, and i can see why after working at the casino. i thought they sucked before i started working there, now i cant even describe how bad i think they are. that being said, i am guilty of dumping 10 bucks into one at the strath every now and then.
its pretty sad seeing people you dont know constantly heading to the atm to gamble, its downright depressing to see friends do it.
And Jarrod, i have the same one!! i keep it on my dash, would get too dirty on the tow hook.
Yeah I got it on the tow hook now. Where on the dash do you have it?
relevance of this little brown monster is???? ive seen it everywhere but got nfi what it is
from memory, somewhat of a cartoon in j.
even if it was just domo waving his arms around screaming domokun over and over.
:P
me wants some 18 by 10 simmons OM's, dark gun metal grey with chrome lip :P
altho these do look amazing in black with red lip :D
http://www.jtuned.com/media/gallery%2FMRT%...RACING-0277.jpg
Edited by rhys5169
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
