i used to work in a few gaming rooms round adel.
and i felt really sick, when i see people back and fourth to the atm
withdrawing 100+ bucks at a time.
and loosing it in a matter of minutes.
and those dumb feckwitts who think there is an ''art'' to playing them and certain ways
you can win IE: rubbing the symbols.
i seriously dont get it.
try being a dealer.
same deal, but people coming back to tables with thousands and losing it all in a matter of minutes.
as for the 'art' of playing, again, try being a dealer, some of the shit you see is as astounding as it is downright confusing.
been doing it close to 2 years, and some of the shit they say and do still catches me off gaurd.
whenever i have a splash on the pokies ill use like 5 bucks maximum, and whenever i win more then a dollar ill take it out, sometimes i put 5 dollars in and come out with 7!
haha, good way to play. stick to a maximum. or f**k it all off and buy another beer. at least you have something tangible then.
:bunny: i find it hilarious that the father of a no pokies campaginer spends most of his time in the grange room
I have watched a mate say he can control himself and make regular trips to the atm, not cool.
yeah, nick is no pokies. emphasis. he has nothing against actual gaming, just against pokie machines, and i can see why after working at the casino. i thought they sucked before i started working there, now i cant even describe how bad i think they are. that being said, i am guilty of dumping 10 bucks into one at the strath every now and then.
its pretty sad seeing people you dont know constantly heading to the atm to gamble, its downright depressing to see friends do it.
And Jarrod, i have the same one!! i keep it on my dash, would get too dirty on the tow hook.
Yeah I got it on the tow hook now. Where on the dash do you have it?
relevance of this little brown monster is???? ive seen it everywhere but got nfi what it is
from memory, somewhat of a cartoon in j.
even if it was just domo waving his arms around screaming domokun over and over.
:P
me wants some 18 by 10 simmons OM's, dark gun metal grey with chrome lip :P
altho these do look amazing in black with red lip :D
http://www.jtuned.com/media/gallery%2FMRT%...RACING-0277.jpg
Edited by rhys5169
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
