White rims really go well with the gun metal grey.. if mine weren't staggered fit you could buy them off me :D
Edited by muirsky
relevance of this little brown monster is???? ive seen it everywhere but got nfi what it is
Think of it kinda like a japneese drop bear, but one that actually has an identity. It's a legendry creature/monster that eats everything, so all the "om nom nom nom" things you see are in referance to this little guy (mostly his teeth and eyes are represented).
cr kai youre only gonna get concaved spokes afaik.
id be lookin into ssr's, or maybe xd9's.
but thats just me.
I know they're concaved, but I mean really concaved.
I dunno.. XD9's would be fat ass actually. White,wide,f**k yeah.
is this THE perfect woman?
>>click<<
aside from the fact that she probably aint single, yeah, she'd be close. :P
funnily enough, i noticed her make an appearance in the wasteland just before you posted that, lol.
pokies? now i know where your name comes from. theyre horrid.
LOL that's not why it's my user name :P
i don't play them that often, if i do i only put $2 in and that's it.
the 1st time i played them i won $70 from putting $1 in :D
so, just for the f**k of it, im gonna post some pics of the new evo, i think theyre rad, reading though the recent mallala thread, seems not many people share that opinion, what does everyone think?
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
