was actually thinking of buying your rims but no money and no car on the road = no buying rims for me :P
they went on another black 32, i think they are going to look better on a black 32 then my blue one
im considering selling mine, want some a little wider...
i acutally downgraded in size, went from 18x8.5, 9.5 to 17x8 and 9 but cant complain for +7 and +17 and much cheaper tyres :D
oh and just picked htem up today too. nicko said they hes going to get me some top of the range cusco coilovers aswell! cant wait :O
soft kye, try buying my tyres :P some of us have tyres that are not kept on stock at most joints
alternative action is to put off buying new 1s and let them get racing slick bald like some other people in the club :D not me officer
Edited by Inline 6
run some stretch mate and youll be right :O ill hook you up!
just after a bit of advise from those in the know. just taking off old turbos to replace with new.. drained oil and water... and then going to replace.. will start and idle to let new fluids circulate through turbos... anything else i need to know?? will my car run just to get it to the mechanics(for a tune) if i keep it under 3 grand?? please pm me if there are any major obsticles.. thanks in advance
cheers and may the force be with you
REGENCY for me tomorrow, im bloody stressing whether ive done everything and havnt left anything out, my car is completly stock as it just came off the production line, evn put the side mount intercooler back inn :)
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
