was actually thinking of buying your rims but no money and no car on the road = no buying rims for me :P
they went on another black 32, i think they are going to look better on a black 32 then my blue one
im considering selling mine, want some a little wider...
i acutally downgraded in size, went from 18x8.5, 9.5 to 17x8 and 9 but cant complain for +7 and +17 and much cheaper tyres :D
oh and just picked htem up today too. nicko said they hes going to get me some top of the range cusco coilovers aswell! cant wait :O
soft kye, try buying my tyres :P some of us have tyres that are not kept on stock at most joints
alternative action is to put off buying new 1s and let them get racing slick bald like some other people in the club :D not me officer
Edited by Inline 6
run some stretch mate and youll be right :O ill hook you up!
just after a bit of advise from those in the know. just taking off old turbos to replace with new.. drained oil and water... and then going to replace.. will start and idle to let new fluids circulate through turbos... anything else i need to know?? will my car run just to get it to the mechanics(for a tune) if i keep it under 3 grand?? please pm me if there are any major obsticles.. thanks in advance
cheers and may the force be with you
REGENCY for me tomorrow, im bloody stressing whether ive done everything and havnt left anything out, my car is completly stock as it just came off the production line, evn put the side mount intercooler back inn :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
