wow that parts list is impressive Mark - can't wait to see what it makes tuned! I am guessing around 350rwkw?
was thinking to myself who the f is mark :) right Jenkies has a first name he got 1 of those 2 :ninja:
they gota go on the car before it makes that :blink: hurry up all ready man
Edited by Inline 6
ummm good question luke, i cant really remember, pretty sure mine still uses the normal brake lines. Matty can probly verify whats needed when he jumps on here next too.
hahah hoping for 300-320 awkw on 16 pound with a nice thick mid range..... exciting times!
Has anyone fitted s13 coilovers to the front of a R31 wagon? if so what needs doing?
cheers
i have mate
you need, s13 hub and nuckles, stub axel, calipers and rotors, s13 tie rod ends....
if you want a hand let me know.
Edited by Ryanrb25
thanks mate, its for my mate. he has s15 front coilovers and wants to chuck them in his wagon. Will let u know if we need a hand.
btw found this http://page.auctions.yahoo.co.jp/jp/auction/111069170 :ninja:
around 15k just for the motor before shipping.
The S15 Struts have a 14mm bolt the holds them to the hub and the S13 has a 12mm hole so you will have to get the uprights on the hub redrilled to 14mm to use them with S15 struts.
EDIT!!
I think it's actually around $1600 not $15,000.
Currency Conversion Results
Symbol Japanese Yen Exchange
Rate Australian Dollar Bid Ask
JPYAUD=X 150000 Sep 24 0.01123 1,684.84901 0.01123 0.01124
Edited by D_Stirls
soooooo f**ked up right now...
OMG DEVILDRIVER!!!!!!!!!!!!!!!!!!!!!!
im going!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
when/how do i get tix?
uhm... dont really know eh.
soundwave sounds awesome
BILLY TALENT FACE TO FACE NEW FOUND GLORY GOLDFINGER
thats enough to convince me :)
new found glory, alkaline trio, and 36 crazyfists are all it took to convince me. :D
i saw devildriver when they came here for gigantour with megadeath, static x and lacona coil
they werent as good as what i thought they were going to be but they did get a good mosh going!
tha some hot polish sausage!!
I got some really hot smallgoods at home, like spicy cabana!
You should try some chilli sauce I got at home :dry: Its rated 10+/10 = nuclear grade chilli :/
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
    • Do this, and we'll have a resource right here.
    • "Hybrid" is a meaningless term. I could not tell you what the vendor of that turbo means by "hybrid".
