sorry to hear dave
last night ruby took me out on his bike we were following ben and nene in the stag and nathan in the 32 and some guy in a purple turbo sigma cut us off, he was so close we could of touched the car, we had to swerve to get out of the way what an idiot i think i made roo deaf in his left ear from screaming
Edited by Bunny33
helloooooooooo from Melbourne :cool::rofl:
my feet and back are killing me from all the walking i've down :)
coming home 2moro yaaaaay can't wait to sleep in my bed
i was in melb from friday and got back tonight :yes:
just HAD to take the 33 out for a drive after leaving it sit for 3 days :rofl:
so glad im home now , got so bored at grandparents house :rofl:
that sucks dave
sry to hear it mate, hope she had a good innings
id like to say she did, but she was only a few years older than my mum. still pretty young considering.
ah sorry to hear Dave
sorry to hear Dave.....good start to the weekend but unfortunately didn't finish that way
as stupid as this sounds, i was waiting for something to come along and f**k it all up, just never thought itd be this.
sorry to hear dave
cheers guys :(
really sucks how often ive received news like this the last couple years, worse again that this is the second time im going to perth to see the family, and the second time i have to bury a family member. funny how its all turning to shit.
haha, it may be because i asked for a touch up tune at mildrens, but a tune after new pfc installation at the others, id assume they think it needs to be tuned from scratch. Well Mildrens is $165 an hour for tuning on the dyno. Im guessing that if i rang back Boostworks and Turbo Tune, it would be cheaper if i mentioned TOUCH UP tune.
Edited by Damo_R34
Ha! I was thinking "He's going to ..." and then he did it. Fruitcake! I slowed and all to have a go at the bastard, but Jake was already at him :( At least he came to apologise ... not many drivers/hoons do that.
Yes, Kell, you almost made me deafer than I already am with you scream "RUBY!!!!!!!". I saw him, now STFU :D
damo ring michael at aussie dyno! see wat he will do!
Aussie Dyno it is, booked in for Thursday 2pm, but not sure if i can get work off at this stage so might have to be Friday. Not sure who i spoke to, but he said about $90 bucks, but they will give it a run on the dyno, which is $70, then fix whatever needs fixing.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
