if its michael doing it, you will be sweet :P
thats the next big shop imho
aussie dyno = top work.
its actually Peter that does it Craig, Michael just sits in the passenger seat and holds the pfc controller...lol
+1 for Aussie dyno
well i think im gonna run
17x9.5+17 front
18x10+18 rears
or stick to the 18x9 +20 fronts!?
good choice my friend....will be good!
+1 for Aussie dyno
Michael is actually tuning the car dan, pete is just running the car up.
Edited by Ryanrb25
+1 for Aussie dyno
where are they located??? i reckon i need to switch workshops as the current one i take my 32 is not that crash hot and now thinking of things they have done im getting pissed off lol
would take it to boostworx but it is too far out the way for me.
cheers
i was in melb from friday and got back tonight :banana:
just HAD to take the 33 out for a drive after leaving it sit for 3 days :angry:
so glad im home now , got so bored at grandparents house :bunny:
we got into Melbourne at hmm 10pm (Vic time).
yeah we left our car parked at the Crown Casino the whole time, too much walking
back and forth, but it was great.
on the way back from parking the car me and my mum walked past 2 guys, 1 said
"what do i do?" and the other guy said "well what you do is ask how they are and how there
night is"
i friggin pissed myself laughing coz well practicing what to say to a girl to pick her up :nyaanyaa:
i miss Melbourne :rant:, i didn't get homesick so yay
well got all the turbo and all piing etc put back on, gave it a quick start
to make sure it still runs :banana:
only thing i noticed is a big amount of smoke :nyaanyaa:
hope its just cos it hasnt been started in ages.....
gotta tighten up all the cooler pipes and final bits ' n peieces, add some coolant
and it shouls be done...... i hope.
all this for one bloody gasket.
Has anyone done pads on the rear with only 2 of the halves having metal tangs in the corner of the pad while the other 2 halves don't?
Anyone knows if it matters whether the pad with the tang goes on the inside or outside of the rotor?
Sample pic only, off a different make of vehicle;
ahh good stuff Luke thanks....I better get back out there and finish off now.
Doing the rear coilovers tonight as well and the fronts tomorrow hopefully.....will post up pics later.
EDIT: Just looked at your pic Luke, that looks more like an anti-squeal shim that goes across the back of the pad......is that what you were referring to or were you talking about the small tang on the bottom corner of the pad?
The tab is just the wear indicator. As 4 piston calipers should wear evenly (equal pressure on both sides and no sliding pins that lock up) it doesn't really matter where it goes.
It's the thing that squeals so you know that your pads are close to worn out before they actually are and you have metal to metal contact
Edited by D_Stirls
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
    • I love saying Samsonas lol. Maybe it's because I secretly want one, but also don't want to sell a kidney.
    • My budget has already blown way out but I've got most of the big-ticket items out of the way haha I just got the box back from the shop, got them to inspect it and install one of those refresh kits with all new syncros and bearings so should feel much nicer. But yeah if there's a weak point it'll be the gearbox, I'm gonna roll with it for now and hope it holds together. Do have an Xtreme organic sprung twinplate clutch to go in so if/when the box lets go I'll be back open for suggestions haha
    • Dose salivating at the prospect of being able to recommend a gearbox upgrade!
