they are 17x 8 +17 fronts and 17x 9.5 +24 rear :dry:
Are they Brentons old meshies? Specs sound similar. Look like they sit pretty mint, full body shots needed (in daylight) though :kiss:
i just went down the street to get drinks for tomorrow, and had a guy come up and introduce himself to me.
it was none other then Mr Senwill himself, he liked my car!(and i liked his, brand new twin turbo range rover, he also has a brand new single turbo petrol one.. :P )
had a chat with him about a bit of stuff, then he gave me a Drift Central 3 dvd! put a smile on my face to meet someone like that in a little town like this, AND he was the nicest dude you will ever meet!
stoked!
Random as
Edited by AndrewJZX100
Well a massive thanks to Ryan, Aussie Dyno and Turbosmart for seeing my car pull 198.1 rwkw today :( apparently im a bashed cat away from 220. ill post up my dyno sheet once i get my camera working. Highly recommend Aussie Dyno, made very very sure i was running 100% safe while still squeezing power out of it!
oh yeah, the hoodies wont be at vili's tonight, due top lack of interest combined with my family down from interstate. next pick up will be my cruise on monday
Edited by Damo_R34
hey mods... can we get aussie dyno into the workshop listings?
Aussie Dyno Mufflers & Brakes Pty Ltd
(08) 8340 0584
373 Port Rd
Hindmarsh SA 5007
exhausts, tuning, dyno (4wd), general mechanics.
cheers
hey guys, after an opinion!
under boost, my 25 is making a high pitched squeel - from area around the turbo; i'm thinking it may be exhaust/manifold leakage.
I havent really investigated by removing bits and pieces under the bonnet yet, - i might take the heat shield off the std turbo tomorrow and have a geeze for any signs of soot and black crap.
Anyone had this issue before?
yes mate i had this exact same problem about a month ago, gasket between turbo and manifold mate...
ahh, so it very well may be the culprit! I asked my usual mechanic, and he guessed that a gasket would probably be the cause.
so basically, you got to remove exhaust front pipe and dump, remove turbo, replace gasket + new studs yeah?
doesnt sound like much, but it'd be a pretty legnthy job hey Ryan?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
