very good...............teed up a time with simon yet?
Not yet, i have a few other things i have to get sorted first, im supposed to be moving into my new house soon, so i have to wait and see whats happening with that before i get the car done.
^ not bitch fights pete,
some people just dont respect other peoples opinions.
i for one, am no angel, but im learning.
just filled out the online entry for find my family.
hopefully they can help me out finding my old man, havent had contact since i was 3, mostly my mums fault.
turning 21 and not knowing the biggest part of me, was really a kick in the pants.
I didn't mention any names Craig and tried to stay in a neutral corner while observing.
mate that's gotta be tuff..........hope you find what your you're looking for and it all turns out good........all the best mate.
Good luck mate. Went hunting for my father years ago ... found him, but didnt turn out too well.
cheers boys, it is pretty tuff, only let it out not long ago, its time for
me to grow up and do somethin bout it...
pete, lol, i wasnt having a go mate, just stating
why people bitch on here all the time,
seems there are too many cheifs, if ya get my drift
thats what im scared of, dissappointing him.......
may i ask how you found him ruby? pm if need be
yeah no probz Craig, I never usually get involved in someone elses battles unless I feel they have been unfairly ganged up on, then I may jump in.....just keep in mind that he's a good mate of mine though.
On another note, notice I said "I hope you find what you're looking for" cause as you can see in Roo's case, he found his Dad but not what he was looking for apparently......all the best bud. :banana:
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
