So how many ppl are after splitfires here? might try and talk to some sponsors and try and get a better deal if we get like 6 sets of them.
and god i had taking spark plugs out they are so annoying to remove eg hoses, covers, pipes
im interested.
lol, youre telling me, have to take half my damn engine apart to get to the plugs.
dunno what it stands for, but they have a cruise 2nd sat of every month, always have a big turnout!
i wanna cruise sat night :)
i aint stayin home with a house full of chicks, that dunno when to keep there voices down!
Saturday night is good too! Got a time in mind? New thread? :O
ive spent the last 4 hours wiring up a new head unit and pulling my car apart to find that the R33 doesnt like 6x9s or 6" speakers !
any suggestions on how to mount rear speakers in an R33 ?
and the doors ?
spewn it must be a 2door thing cuase i have 6x9 in my car i think i mounted them from underneath in the boot :O
onboard pro drifting ftw
>>Download<< 9.7mb
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
