last i heard she was in intensive care cause she couldn't breathe right and her heart rate had significantly increased
that's all ive heard , going to go over to her mums place this afternoon probably seeing as i was the first person she called cause we hang out
every weekend and she knows about me etc etc
respiratory problems would indicate more than just alcohol poisoning you would think...........be interesting to see what the lab results bring tomorrow
yeah sorry to hear mate,know exactly how u feel,i cant seem to go anymore than a few mths without bad news,my brother is still in hospital after his bike accident two weeks ago,just got to try and stay positive and hope life gets better :(
Heard about that Damo. Didn't feel it was my place to bring up that topic with ya ... but wishing him the best anyway mate. :ermm:
PM me if ya want.
BTW Cam's birthday is coming up soon and the girl is invited (and you guys of course). Looking at doing an Aquatic Centre birthday thingy if our pool is not up and ready in time.
anyone watching the story on ethenol on 60 minutes?
60mins FTL.
Its good stuff and has been used oversea's for quite some time without issues.
What was it they are claiming? :ermm:
The basics are
Old fuel pumps = they break
Old fuel hose = they break
Skylines.. Replace the fuel pump and rubber hoses and up to >40rwkw (if not more when you push in more boost etc) at the disposal of your right foot:)
Fuel economy can take a hit if not tuned correctly.
PM me if ya want.
My girlfriend and I will be around! :(
Came home last night from my sister's to find my dog on the street corner. Found out how it got out ...
Some trespasser(s) tried to get into my property. Rollershutters all around and good security, so they tried the backyard. Forced the side gate open and discovered our black staffie. They musta shat themselves, because thats as far as they got before running. Obviously my dog gave chase and we found her around the corner from the house, so we just missed them by mere minutes :(
Went and got a few extra items today :)
"Beefing up the home security" :ermm:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
