well lucky it wasn't! but the car is black with some club sticker on the back and 19"+ chromies with a custom number plate! and plus his car was loud as a mofo
I would of just ignored the commo :) might of been an undercover... too risky... damn new commodores lol
yeh my mate in the gold CV8Z monaro said he saw every1 scatter...lol
i cracked up laughing when he told me n i thought 2 myself "i bet that was craig's organised cruise"
dob on u 4 wat?????????????????????
hey was it u that had a mate with a vxss??? was it gold??
na i dont have a mate with a vx ss, i have one with a worked vx berlina though, me and him where dead equal
everytime we had a go (on private road) even though i had mass wheelspin through 1st 2nd....
cant wait to see your car on the road again man, it porn!
yeah sorry about that Carl............you should see me on a bad day :D
hahaha, its all good, 99% of the time its water off a ducks back with angry ppl. in my last role i was a TL for 13 engineers that work with secure coms (VPN's and hardware firewalls)... all i used to deal with was escalations, so i have a really good grounding in conflict resolution.
one thing that always gets me on the front foot is when someone that starts a conversation/query with "listen...", i find that quite rude. (this is not meant to offend but i find 99% of the ppl that say this are of a common nationality/background)
Bezender.. Get in to a company where you can work your way up and get away from being a CSO.
Internode is a good example. Admittedly you may take a pay cut from telstra/optus for the first couple of years but after 1year 2 absolutely max if your your not all that keen and your up and away from front line support.
i have put my resume in to move to there and take a $18k paycut... the money does not phase me, i'd rather have satisfaction. gotta keep slogging away with my mcse and ccna in the mean time
^ hey Ryan you/your place of business can retune stock ecus yeah?
My car is out of tune since I swapped the exhaust and wondering what sort of rough price I'd be looking at to get it touched up. It has already had all the stuff put in to be able to tune, so should hopefully only need a few hours to rectify a/f ratios, it's fking eating fuel big time at the mo :rofl:
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
