well lucky it wasn't! but the car is black with some club sticker on the back and 19"+ chromies with a custom number plate! and plus his car was loud as a mofo
I would of just ignored the commo :) might of been an undercover... too risky... damn new commodores lol
yeh my mate in the gold CV8Z monaro said he saw every1 scatter...lol
i cracked up laughing when he told me n i thought 2 myself "i bet that was craig's organised cruise"
dob on u 4 wat?????????????????????
hey was it u that had a mate with a vxss??? was it gold??
na i dont have a mate with a vx ss, i have one with a worked vx berlina though, me and him where dead equal
everytime we had a go (on private road) even though i had mass wheelspin through 1st 2nd....
cant wait to see your car on the road again man, it porn!
yeah sorry about that Carl............you should see me on a bad day :D
hahaha, its all good, 99% of the time its water off a ducks back with angry ppl. in my last role i was a TL for 13 engineers that work with secure coms (VPN's and hardware firewalls)... all i used to deal with was escalations, so i have a really good grounding in conflict resolution.
one thing that always gets me on the front foot is when someone that starts a conversation/query with "listen...", i find that quite rude. (this is not meant to offend but i find 99% of the ppl that say this are of a common nationality/background)
Bezender.. Get in to a company where you can work your way up and get away from being a CSO.
Internode is a good example. Admittedly you may take a pay cut from telstra/optus for the first couple of years but after 1year 2 absolutely max if your your not all that keen and your up and away from front line support.
i have put my resume in to move to there and take a $18k paycut... the money does not phase me, i'd rather have satisfaction. gotta keep slogging away with my mcse and ccna in the mean time
^ hey Ryan you/your place of business can retune stock ecus yeah?
My car is out of tune since I swapped the exhaust and wondering what sort of rough price I'd be looking at to get it touched up. It has already had all the stuff put in to be able to tune, so should hopefully only need a few hours to rectify a/f ratios, it's fking eating fuel big time at the mo :rofl:
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
