Off topic, but +1 to Service SA messing people around. I got told a few weeks back on the phone from them "Yep, you can get your full license. Just come in and get it". So I went down there and the girl behind the counter said "Nope, you can't get it for another 4 weeks. The person on the phone was wrong".
Stupid! 0 customer service skills.
Yep, service SA suck! Was supposed to get my P's back about a month ago, now it'll be another 5 weeks or so.. BULLS**T!!! Had one lesson on my L's the other day (as you have to these days) and the dude said i need to have a few more lessons to 'break some habbits' i have, these habbits are the ones i learnt from the first driver i had before i got my P's 2 years ago.... Its alittle hard to break them seeing i've been doing it for 2 years.. Also why the hell do they need me to do the VORT test? I've had my p's, there for i know how to park, do u-turns and all that shite, so whats the point????? It pissed me off so much when the dude told me that, swear i was gunna hit him at one point, not his fault tho, just doing his job! But seriously why do i havta do all that stuff again, i was caught speeding thru a few red light spped cameras (within 20k's) and this is what i get for it, 8 months (or more if i done pass the VORT) with no licence = bullshit! Stupid system!!!! But yeah i guess... its my own fault... :laugh: dont lose ya licence when your on your P ones.. it sucks what ya havta go thru to get them back!
My rant lol
GTR Pump will fit BUT for the cost of an old S/H pump why not buy a new 040 or 044 and fit that intank.
I fitted my 044 intank, cost $20 for the lower machined nipple a hose clamp, some suitable rubber and a little efi hose.
new pump 040 is like $220 -,-"
ebay my friend. :laugh:
some jecs pump - http://cgi.ebay.com.au/JECS-BOSCH-FUEL-PUM...1QQcmdZViewItem
and then a heap of 044's for around $200 delivered.
Theres also the Walbro which is a damn good pump for up to ~250-260rwkw.
^^ yup, had walbro in my 33, 230 odd rwkw comfortably, stock injectors where @ 100% at times
ERRRRMMM WHY IS MY LAPTOP WRITING IN CAPS WHEN CAPS LOCK IS OFF?
and lower case when caps lock is on? :laugh:
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
