Took a sickie today.
Didnt get up until 12 noon. Now I've been bored all day. :P
Would have been a great day to ride thru the hills ... but I'm too sick to ride :P
evening everyone.
So i did a good deed just now.. saw a dead cat on melbourne street n felt sad so i turned around and stopped and helped another lady drag it off the road.. poor kitty :P
Im a sucker for animals :P
Felt sad so decided to give my cat a hug when i got home, all i got was a scratch on the face and a hiss.
But yeh, theres my good deed for the week
um when i saw him run on the saturday he made 285 AWKW and 301 RWKW i doubt from one day to the next hes going to loose 30 awkw's :P
tiz true.. when my car ran on saturday they also diddnt put enough petty in.. had below 1/4.. might have something to do with it.. i dont know.. was workin sat :P but what i do have is the figures of previous tune results.. can scan in dyno sheets if need be. thanks for the comments and smiles bout engine.. yeh im pretty happy visually with it too...
chad, yeh just had to chuck the trophy in there.
G zilla back with mozilla :(
special thanks to dohmar for his pc skills
plug in for the man who don't like to self advertise;
for all your pc fixing needs contact dohmar :P dude hooked me a sweet custom made pc running a twin turbo nos setup to smoke any rival pc.
pm dohmar to get him to hook up your busted pc today :P if he's not too busy running up his credit card and changing the lights inside his dash to the 5th colour he's had
Edited by Inline 6
um when i saw him run on the saturday he made 285 AWKW and 301 RWKW i doubt from one day to the next hes going to loose 30 awkw's :blink:
tiz true..
would look pretty defectable personally 18's are enough and once you go to a 19" tyres whoa mumma prepare to pay for rubber
Even the jump from 17" to 18" is a big jump in price unfortunately :P but yeah, i recommend 18"
went and had my car remapped at turbo tune today and i gained 34 rwkw out of it
first run pulled 88.1 rwkw with a blocked fuel filter and fooked fuel pump..so replaced both of them and it pulled 111.2 rwkw
then after the remap it pulled 122.2rwkw..
im pretty happy with it considering the only mods are HD clutch, 2.5" full exhaust system with race cat and K&N panel filter
Ryder, hurry up and get a turbo!!
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
