MMmmMMmmM i know Pete will like this one http://www.j-spec.com.au/list/index.php?ID=13629
yes, very nice Damo...........notice what he said about good 32 GTR's starting to go up in price at the bottom of the page.....I think the Iron Chef has said something similar in the past.
anyone seen the article on 32 gtr's, namingly aus delivered ones in the latest motor magazine???
What does it say in a nutshell?
I'm happy to do so. It's all fun and games :D
Ah it will. ignore the manifold, this is a pic of the turbo during a trial fit.
and what's with SA not having any drag strips?
cos the SA government Fails hard :rofl: ... always has and always will....
basically that they are one of the greatest cars produced, that the times they did back in the 90's is still quicker than basically any time coming out of holden & ford camps. they had a f-ing mint concourse aus delivered 32 gtr. worth a look if you get a chance, motor magazine with the new corvette on the front. the article is in the back
or you could scan it
imagine if the gtr was still included in the supercars race, like any of those bogan spec cars would keep up to mark skaife and jim richards in the R34 GTR N1 :rofl:
hardly a fair fight is it its like putting jeff fenic up again Evander holyfield
lol i think holden would either cheat that little bit more or pack up and go home
Tell me which team you'd like disqualified then :D
I'll be managing a team garage at the Phillip Island round of the V8 Supercars next year. I have the power to disqualify a team if they don't follow the rules on pit stop allowances. :rofl:
"In India, it is cheaper to have sex with a prostitute than it is to buy a condom"
"Jack Nicholson was 37 when he found out that his sister was actually his mum"
"The year on a vintage bottle of wine indicates the year the grapes were picked, not the year it was bottled"
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
