lookin after a tropical tank is easy peasy just need a good filter, i bought my fluval fx5 about a year ago and only changed the water every 6 months and fish still happy =D just remember to feed the fishes thats all you need to worry about.
Yeah if you do it right you can pretty much have the aquariums look after themselves.
I had tanks for 15 odd years before I moved into my old place and havent bothered to set another one up...
Best advice is to get a powerhead and attach it to an undergravel filter, and then get some hardy fish in to start the bacteria culture up... add the plants and stones and what not, and give it at least a month before putting the really expensive fish in...
Livebearers (guppies, platys, mollies) are pretty tough, you can use fighting fish (bettas) as well since theyre from cambodian bogs and have the ability to breathe oxygen from the air... just make sure when you get an aquarium you plan the mixture of fish. Nothing worse than putting an angelfish or a red tailed black shark in and have them bully every other fish in the aquarium... get some docile fish like bumblebees or kuhli loaches, some catfish to keep the gravel clean of uneaten food and a couple of golden snails to eat algae (or a bristle nosed catfish)... you'll have a nice lookin' tank in no time
just dont skimp on the plant life or the equipment
-d
My dad has had his tropical fish tank up and running i reckon for atleast most of my life. Hes gone through two fishtanks...both 4 foot ones. His original one broke, he tried to save some of the fish by putting them in a plastic tub...only fish that lived was a clown loach (this was like 10 years ago maybe??) and that clown loach is still alive today - bloody hardy fish.
He's also gone through his fair share of discus - love the fish but keep seeming to have trouble with them dying. He recently had some weird disease with his discus, killed 4 of em :)
And since then hes bought another 5, one of em which liked to chase all the others so hes got it seperate in a clear plastic box thing in the tank haha.
But yeah dads got clown loaches, cardinal tetras, a few of the guppies from my tropical fishtank on my bedside table ;) , congo tetras and a shitload of bristlenosed catfish cos they had babies :P
My lil 22lt tank is currently down cos with year 12 i don't get the chance to change the water....but dad changes his every week - 40%. Trying to keep those bloody expensive discus alive. But yeah, after year 12 i'll have it going again....dad suggested getting a breeding pair of cichlids....so we'll see how that goes. :(
Anyway...just thought i'd share - some people are REALLY sto0pid....fail??
i was never into fish but once i started with a small 1 foot tank for my bday i never went back, started of with lil 'neons' , angel fish, lil cat fish, upgraded to 3 foot than 4 foot and now i have a 6 foot lol
p.s if anyone know where i can buy a red arowana LET ME KNOW!!! ill pay good money ^_^
for people that dont know looks like this.. i got the silver version but red looks 10000x better
http://au.youtube.com/watch?v=wkUMd75BBiw&...feature=related
*groan* Went bike browsing at lunchtime today ...
Now I wanna sell my MV F4 Brutale ...
$20,990 (retail)
101 rwkw
96 Nm
185 kg
257 kph max speed
(which has lots of carbon bits, Ohlins suspension, PCIIIr ecu, crash protection and full hi-flow system)
And get this ... an MV F4 1000
$26,990 (retail)
122 rwkw
109 Nm
192kg
301 kph max speed
Both bikes have engines designed and built by Ferrari (F4 = Ferrari 4 cylinder) *drool*
Bah i like the new model with the 1078cc engine.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
