Vu,
Did you pull the squeel shims off the old brake pads and clipped them on to the new? 'Sometimes' its easy not to see the squeel shims on the old pads if they are dirty and full of brake dust.
Had a mechanic fit the brake pads and rotors up and yeah he did the shims - everything looked to be done well and bedding in was done according to the instructions from the brake pads. I'm gonna take the pads out sometime in the next couple days get some anti-squealing shiz into it see how it goes then... damn thing is driving me nuts!
yeah my EBC Redstuff (ceramic) is doing the same thing now....loud as with a medium pedal but goes away with hard braking and I used the stick on anti squeal pads to
ive got the same pads pete but i have not had a problem with them squealing did you bed them in properly.?
yeah they have that thin compound on them that requires light to medium use initially before giving them the usual bed in process (from 100kph down to 15kph several times till hot then cool down and repeat if necessary)
I haven't done that final process yet cause they were only put in 150 km ago but I think they may be ready for the final process now.........hope that fixes it.
On another note, do they bite those rotors or what.....very unforgiving even on initial grab and wants to throw you thru the windscreen everytime, lol
I dont know if thats meant to be done with my brake pads but hell I'm going to give that a try see if that works!
anyone keen to come bowling friday night? Salisbury Bowland, 8:00, $19 for 3 hours of bowling
Friday night is my Vili's and cruise night :) do you remember that place?? its where most of use to hang out on Friday nights :)
I put a chamfered angle on the leading edge of new brake pads to stop them sqeeling.... nothing over the top use a file and take the sharp edge away. it has alwayz worked for me :)
i did the same with my pads mick, made the squeeling stop enough for me to hear my dodgy wheel bearing on the front passenger side :)
i remember reading on here a while back that one of the SAU members works for CBC, any one remember who?
i did the same with my pads mick, made the squeeling stop enough for me to hear my dodgy wheel bearing on the front passenger side :D
that could be a blessing in disguise.... not fun when they collapse totally :)
i have some red goo stuff that heslo luke told be to buy when he did my rotors
and pads,
never heard on squeel from my brakes, no matter how hot they got,
its still pretty much full tube, you can have it
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
