Stupid computers today!
One reception PC power supply has died.
The receptionist can't log on and get her desktop up on my share PC in my office ... so I've put her on my drafting PC.
So I'm stuck in my office using a less than adequate PC for drafting today!
IT guy should have been here an hour ago! I'd do it myself, but I'm too busy for that shit. :P
Hello all Forum members - finally we have joined SAU
Team wheelworx
Welcome aboard. :P
$200 a week I heard, just to drive that yank tank to work and back each day. Bloody hell :laugh:
Good point! The Evo's used to be alot more 'boxier' but have now made them a bit more smoother. They both have similar front ends, too - complete with the bonnet vents (but Evo's have had this since the day dot).
Nissan just can't get away from those headlights! R35, 350z and now the 370z will have them, too!
any one else think these cars share very similar lines??
Anyone else think they both look like shit too?
Can't stand new car design. Whether it's putting massive fk off grill areas (like the 2 above, and Audi is a culprit of this too) or headlights that creep half-way up the bonnet or complicated panel work (looking at you, BMW) theres just something that shits me about new cars.
Tasteful and restrained, 2 words that seem to have disappeared out of car designers vocabulary over recent years :P
gezzz mick ur getting ur post count up quick lol
should i stop posting stuff now or wait till later........hahahahaha......not much else to do and some of these threads are pretty good for a laugh......
besides being social beats the ps3...lol :P
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
