pretty sure your going to need gtr headlights dude
see im not that dumb i was right
you may get away with headlight spacers to bring the original one's forward, i know that's what you can do with R33 > GTR conversion
edit
oh bunny :P
yeah i do to and im fine now a little hurt but fine i acually see the funny side of things a bit anyway. drop kick is a understatment
Kell, before I met Tracy, I dated a 25yo for about 2 months. We got along real well, or so I thought. She started going cold ... like had no time to see me. I go over there and demand an explanation, she hands me a note. The contents were unclear and bs anyway, so I just left. If its no good, its no good. I had my suspicion she deveoped an interest in someone else. Im not stupid. I told her my theory and at first she didn't deny it ... guess she didnt think I was smart enough to catch on quick.
Anyways, goes to show guys get the screw around too ... good thing is I have Tracy now :P
well oh well ill just cruise with locky if someone comes along then good and if they don't then ok its really to hard to find someone that doesn't care about the car i drive or that i have a son so i officially give up
so yeah , RB25DET wont be happening for a few months to a few years etc etc ,
gonna work the crap out of my RB25DE for now
suggestions for getting some more power out of my N/A ?
im thinkin something like
Port and polish
oversized valves
cams
gasket ?
y bother!!???
spend it on the 25det u fool lol.....
worst thing i did was spend money on the 20!
True. By the time you work the DE, you could have fit in a DET and sold the DE and make some money back!
hahaha i gave up a while ago!
we will get to gether adrain i mean we already slept together camping hahaha
Didn't the girls give up first :yes:
Kell, thats when things usually happen ... when you're not looking. :P
nope im over it
Port and polish
oversized valves
cams
gasket ?
dont bother. huge amounts of coin for very little tangible difference. like i said on that cruise the other week up in lofty, either harden and get a DET, or strap a vortech (or even a commo v6 roots type) and a W2A intercooler to the DE with a flashed ecu.
Edited by scandyflick
yeah i don't know man , just gotta wait n see how my financial situation pans out in the coming months i guess
Ok this may just be me, but is anyone else's post times going all over the shop?
Like just then on the main page it said the last post in this thread was at 1:03 (ie hasn't updated to daylight savings time) but when I go into the thread the same post reads as being posted at 2:03 (the correct daylight savings time)
Like I said, may just be me absolutely tripping balls.
yet you talk of
...Port and polish
oversized valves
cams
gasket ?
there all not cheap, hang onto your coin save save save and before you know it throw a RS4 engine in it and you will be ever so please you waited and not wasted 2.5k on worthless mods to make a make of 40-50kw
+1
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
