pretty sure your going to need gtr headlights dude
see im not that dumb i was right
you may get away with headlight spacers to bring the original one's forward, i know that's what you can do with R33 > GTR conversion
edit
oh bunny :P
yeah i do to and im fine now a little hurt but fine i acually see the funny side of things a bit anyway. drop kick is a understatment
Kell, before I met Tracy, I dated a 25yo for about 2 months. We got along real well, or so I thought. She started going cold ... like had no time to see me. I go over there and demand an explanation, she hands me a note. The contents were unclear and bs anyway, so I just left. If its no good, its no good. I had my suspicion she deveoped an interest in someone else. Im not stupid. I told her my theory and at first she didn't deny it ... guess she didnt think I was smart enough to catch on quick.
Anyways, goes to show guys get the screw around too ... good thing is I have Tracy now :P
well oh well ill just cruise with locky if someone comes along then good and if they don't then ok its really to hard to find someone that doesn't care about the car i drive or that i have a son so i officially give up
so yeah , RB25DET wont be happening for a few months to a few years etc etc ,
gonna work the crap out of my RB25DE for now
suggestions for getting some more power out of my N/A ?
im thinkin something like
Port and polish
oversized valves
cams
gasket ?
y bother!!???
spend it on the 25det u fool lol.....
worst thing i did was spend money on the 20!
True. By the time you work the DE, you could have fit in a DET and sold the DE and make some money back!
hahaha i gave up a while ago!
we will get to gether adrain i mean we already slept together camping hahaha
Didn't the girls give up first :yes:
Kell, thats when things usually happen ... when you're not looking. :P
nope im over it
Port and polish
oversized valves
cams
gasket ?
dont bother. huge amounts of coin for very little tangible difference. like i said on that cruise the other week up in lofty, either harden and get a DET, or strap a vortech (or even a commo v6 roots type) and a W2A intercooler to the DE with a flashed ecu.
Edited by scandyflick
yeah i don't know man , just gotta wait n see how my financial situation pans out in the coming months i guess
Ok this may just be me, but is anyone else's post times going all over the shop?
Like just then on the main page it said the last post in this thread was at 1:03 (ie hasn't updated to daylight savings time) but when I go into the thread the same post reads as being posted at 2:03 (the correct daylight savings time)
Like I said, may just be me absolutely tripping balls.
yet you talk of
...Port and polish
oversized valves
cams
gasket ?
there all not cheap, hang onto your coin save save save and before you know it throw a RS4 engine in it and you will be ever so please you waited and not wasted 2.5k on worthless mods to make a make of 40-50kw
+1
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
