Hi everyone im back :P im now living in my new house :huh: my laptop shat itself last week so i gave it to my mate to fix and only just got it back today, so what have i missed??
everything babe just go back about 300 pages and you will be ok
Rb30 keeps the 4wd and the low mounts (as low mounts are part of the head).
Everything bolts on as per normal. The sump adaptor bolts on to the bottom of the rb30 block and then on to the 4wd sump/diff.
3k.. Sounds like an AFM issue. Make sure all the IC pipes are connected properly.
probably roughly 10k i assume for HKS version
Wanna keep the 4wd tho, and twin low mount's
Also Cubes brother has a R32gts-t got new coilpacks, plugs and serviced recently. anything over 3k the car starts chugging, any idea what it would be?
what cubes said! tell craig to get another afm. if he wants he can test mine out on his 32.
the cars gone into limp mode or whatever its called. happened to me and its a pain to drive!
hey ruby.... looking at getting a motor bike...
wats a good bike to look at? beginner also :thumbsup:
why you asking him.........you know what he's gonna say
"if it aint Italian, it aint worth havin", lol
Here's a bit of education for you:
2008 Fat Boy
2008 Night Rod Special
2008 Road King Classic
oka so should i go a hks hipower or a hks silent hipower cat back exhaust for my 32???
oh and will an R32 GTR cat back one fit a gtst/gts4 ??
need ya opinions
cheers
Edited by vinnie32GTS4
well, Ive been quoted petrol money change out of 2grand to fit and tune the following:
Cometic intake manifold gasket
Cometic intake collector gasket
Cometic exhaust gasket
Cometic Head gasket 1.2mm x 87mm
ARP head stud kit
EPP 6mm viton Intake valve seals
EPP 6mm viton Exhaust valve seals
EPP Intake valve seats
EPP Exhaust valve seats
EPP Intake valve guides
EPP Exhaust valve guides
Q45 90mm throttle body
Greddy Q45-RB25 adapter kit
EPP clear cam gear timing belt cover
Tomei oil gallery restrictor orifice
Tomei hi-lift valve springs ~8.8mm
Tomei 256/256 poncam camshaft set
Gates Racing timing belt kit incl. tensioner and idler
2x 700cc Sard injector external intake manifold setup
ryco oil filter, oil filter magnet set & Motul 4100 turbolite 10/40w oil
Need a controller for the extra injectors tho........................
expect, with the sards, there should be enough fuel injc. headroom to push a nice comfortable 230kw tune., with heaps big torque
:thumbsup:
then thats it, bar pistons/rings and rods/bearings; maybe in 5yrs time. lol
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
