:D yeah good luck with that.
Go the 31 if you just wanna go out and thrash something. Take your 34 out there if you want to learn more about the car/driving in general. Once you get over the fear of bending a good car its much more fun.
AE86's START at 9k imported...
And that's with only 10% covered in rust!
dont know where you 2 guys are looking for AE86's
http://www.tradecarview.com/used_car/japan...trueno/1455433/
http://www.tradecarview.com/used_car/japan...trueno/1381123/
http://www.japaneseusedcars.com/auction/tu...o-28691719.html
http://www.tradecarview.com/used_car/japan...trueno/1111544/
http://www.tradecarview.com/used_car/japan...+levin/1515519/
and there not the cheapest spec ones
Hmmmm
need money :P
50mm wide body rears for a 32 4dr ;)
Would look fking ace with some GTR front guards & bar.
find those for a R33 4 door and i will love you for ever
I got fruchocs and coke! Close enough.
So im confused but agree with Adrian KEEP IT OFF THE DAMN FORUMS!
i used to work a robern menz :down: mmmm chocolate coated orange bits
Boring.....
Bitching on the net is gay and having to read through it to find the good things to read is even more homo. Is SAU full of 16 year olds now or what?
Because I'm bord, I'm going to borr you all with me. Here's some dodgy pictures I took not long ago. It's only a shitty old camera and ive never done anything fancy with one before so cut me some slack :D
all depends on the yen on the day general rule of thumb
car cost Yen FOB = at the docks
$1100 shipping+10%gst+10%customs+$600 Quarantine & other government charges+ $3000 compliance + broker fees
OH YOUR SO BORING KYE...
.no really you are JK lol good job man
PLEASE!!! i would kick your ass at halo and i dont even touch that gay-box 360 anymore :D
dont be mad dan, one day ill let you back around to play some more ps3 :down: .................................one day
cheers steve ;) you funny bugger
Edited by Import S13
Those pics r sex. Love the paint job.... wish I had one as good ;P
-D
thats gaylo 3 to you
and way to make me realise the tool i am having to nag the rich kid to play the latest and greatest games :D can i come over mum says its ok
im still playing galaga here, apparently games have moved into a get this "3rd dimension"
forgot to put ur window up ;) n get a night kids sticker
Edited by Inline 6
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
