my car started misfiring under high load the other day (ie ~5500 whilst wheelspinning in 2nd) so I took one of the spark plugs out (CBF doing the rest :) ) and it looks like this:
Is the whiteness something to be worried about?
Anyone?
Gap looks standard 1.1mm ?? should be 7-8mm i think mine are even 6mm i was planing on running large boost
as for whiteness i don't think its anything to worry about i think its heat affected metal ??
i found this 1,627,500.00 JPY (Japan Yen) = 26,404.34 AUD (Australia Dollars)
>>source>>
RB30 OS-E2996
Developed for those special customers who feel that 2.6 liters is just not enough.
OS Giken RB30kit contents
RB30 OS-E2996
- 1 cyclinder block
- 1 billet crankshaft
- 6 billet-forged connecting rods
- 7 crankshaft main bearings
- 6 connecting rod bearings
- 6 forged aluminum pistons
- 1.3mm metal gasket (1.2mm, 1.4mm and 1.5mm
gaskets available)
- 1 timiing belt
- 1 belt tensioner kit
- 14 custom made reinforced crank cap stud bolts and
nuts
- 3 M6 bolts
Now that I can believe.........$AU26,000 for an OS short motor that includes a full counterweight & big stroke crank with sleeves, deck plate and all the you-beaut internals.
I just can't see why someone would pay $30K for a block alone that can still pound a brg, crack a land, throw a rod, etc, etc!!
Yeah I noticed the gap was kinda big for our cars. Anyone up for a drive to the hills to help me change em for a 6pack o beers? :)
Feel free to bring the car down to Campbelltown though. i just got home from work and will be up for a bit. lol
what are your thoughts on this looks responsive enough and a little more balls than the 2871r just suggestion.
~GT2876r click me~
The GT2876R is a poor mismatch between the turbine and compressor. The 76mm compressor wheel is too big to be driven by the T28 ns111 turbine wheel.
This is highlighted on the Garrett website where they say;
* Not recommended for general performance applications
* Best suited for unique applications such as asymmetric turbo installations
Edited by D_Stirls
Hey mate,
I work in irrigation facing Currie street. I wouldn't be surprised if you didn't even know we existed, no one does!! lol. It has been decided that we have the better spot as we have windows facing the main road.. Let's just say, during uni and summer, awesome views!! lol
Anyway, the wheels...... What are you after for them? I have a mate that is a BBS fan boy who might be interested if I give it a miss. Can post pics if possible?
Cheers,
Peter.
Thought I'd move this post to Wasteland so Andrew, Joel or Matt don't smack us, lol.
Here's what they are.........haven't thought about price at this stage........265 x 35 x 18
Gap looks standard 1.1mm ?? should be 0.7-0.8mm i think mine are even 0.6mm i was planing on running large boost
FIXED
i wouldn't go any lower than 0.7mm, No need to and it effects your idle. Will bounce and pop at idle if any smaller.
It's amazing that the block costs that alone AND that Keir has blown 5! What is the exact difference in the OS block that makes it so awesome?
It is an engineering piece of art .... and people make serious power with them, that they just cannot make with a normal block
Nice find Steve - you do realise of course that it would cost you $10k+ to get it here including shipping, taxes and GST?!
Seems the price has come down somewhat .... mind you, it doesn't look like that is coming directly from OS Giken (with all of their associated knowledge and warranty that comes with it), so I guess it is from a cheaper distributor or something. Also sounds a bit fishy, since it says in 1 place 3lt (2996), but in other places it says 3.15lt. I guess that is a head gasket and piston stroke issue maybe.
Had a tinker around with the GTR last night and found that it still has the stock boost restrictor in one of the vacuum lines (Nissan put it in to meet the gentlemen's agreement and circled the line with a yellow stripe, etc etc etc).
Can't believe that none of the previous owners in Japan took it out to get a safe boost increase! Crazy.
parking in a loading zone that turns into a taxi zone at 6pm = fail, $79 fail
ahwell, my fault lol
parking on a main road at 11am that turns into a bike lane at 3pm. then get stuck doing shit when you thought you were only gonna be there a couple of hours and leave at 4:30pm = $148 fail!! :yucky:
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
