my car started misfiring under high load the other day (ie ~5500 whilst wheelspinning in 2nd) so I took one of the spark plugs out (CBF doing the rest :) ) and it looks like this:
Is the whiteness something to be worried about?
Anyone?
Gap looks standard 1.1mm ?? should be 7-8mm i think mine are even 6mm i was planing on running large boost
as for whiteness i don't think its anything to worry about i think its heat affected metal ??
i found this 1,627,500.00 JPY (Japan Yen) = 26,404.34 AUD (Australia Dollars)
>>source>>
RB30 OS-E2996
Developed for those special customers who feel that 2.6 liters is just not enough.
OS Giken RB30kit contents
RB30 OS-E2996
- 1 cyclinder block
- 1 billet crankshaft
- 6 billet-forged connecting rods
- 7 crankshaft main bearings
- 6 connecting rod bearings
- 6 forged aluminum pistons
- 1.3mm metal gasket (1.2mm, 1.4mm and 1.5mm
gaskets available)
- 1 timiing belt
- 1 belt tensioner kit
- 14 custom made reinforced crank cap stud bolts and
nuts
- 3 M6 bolts
Now that I can believe.........$AU26,000 for an OS short motor that includes a full counterweight & big stroke crank with sleeves, deck plate and all the you-beaut internals.
I just can't see why someone would pay $30K for a block alone that can still pound a brg, crack a land, throw a rod, etc, etc!!
Yeah I noticed the gap was kinda big for our cars. Anyone up for a drive to the hills to help me change em for a 6pack o beers? :)
Feel free to bring the car down to Campbelltown though. i just got home from work and will be up for a bit. lol
what are your thoughts on this looks responsive enough and a little more balls than the 2871r just suggestion.
~GT2876r click me~
The GT2876R is a poor mismatch between the turbine and compressor. The 76mm compressor wheel is too big to be driven by the T28 ns111 turbine wheel.
This is highlighted on the Garrett website where they say;
* Not recommended for general performance applications
* Best suited for unique applications such as asymmetric turbo installations
Edited by D_Stirls
Hey mate,
I work in irrigation facing Currie street. I wouldn't be surprised if you didn't even know we existed, no one does!! lol. It has been decided that we have the better spot as we have windows facing the main road.. Let's just say, during uni and summer, awesome views!! lol
Anyway, the wheels...... What are you after for them? I have a mate that is a BBS fan boy who might be interested if I give it a miss. Can post pics if possible?
Cheers,
Peter.
Thought I'd move this post to Wasteland so Andrew, Joel or Matt don't smack us, lol.
Here's what they are.........haven't thought about price at this stage........265 x 35 x 18
Gap looks standard 1.1mm ?? should be 0.7-0.8mm i think mine are even 0.6mm i was planing on running large boost
FIXED
i wouldn't go any lower than 0.7mm, No need to and it effects your idle. Will bounce and pop at idle if any smaller.
It's amazing that the block costs that alone AND that Keir has blown 5! What is the exact difference in the OS block that makes it so awesome?
It is an engineering piece of art .... and people make serious power with them, that they just cannot make with a normal block
Nice find Steve - you do realise of course that it would cost you $10k+ to get it here including shipping, taxes and GST?!
Seems the price has come down somewhat .... mind you, it doesn't look like that is coming directly from OS Giken (with all of their associated knowledge and warranty that comes with it), so I guess it is from a cheaper distributor or something. Also sounds a bit fishy, since it says in 1 place 3lt (2996), but in other places it says 3.15lt. I guess that is a head gasket and piston stroke issue maybe.
Had a tinker around with the GTR last night and found that it still has the stock boost restrictor in one of the vacuum lines (Nissan put it in to meet the gentlemen's agreement and circled the line with a yellow stripe, etc etc etc).
Can't believe that none of the previous owners in Japan took it out to get a safe boost increase! Crazy.
parking in a loading zone that turns into a taxi zone at 6pm = fail, $79 fail
ahwell, my fault lol
parking on a main road at 11am that turns into a bike lane at 3pm. then get stuck doing shit when you thought you were only gonna be there a couple of hours and leave at 4:30pm = $148 fail!! :yucky:
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
