my car started misfiring under high load the other day (ie ~5500 whilst wheelspinning in 2nd) so I took one of the spark plugs out (CBF doing the rest :) ) and it looks like this:
Is the whiteness something to be worried about?
Anyone?
Gap looks standard 1.1mm ?? should be 7-8mm i think mine are even 6mm i was planing on running large boost
as for whiteness i don't think its anything to worry about i think its heat affected metal ??
i found this 1,627,500.00 JPY (Japan Yen) = 26,404.34 AUD (Australia Dollars)
>>source>>
RB30 OS-E2996
Developed for those special customers who feel that 2.6 liters is just not enough.
OS Giken RB30kit contents
RB30 OS-E2996
- 1 cyclinder block
- 1 billet crankshaft
- 6 billet-forged connecting rods
- 7 crankshaft main bearings
- 6 connecting rod bearings
- 6 forged aluminum pistons
- 1.3mm metal gasket (1.2mm, 1.4mm and 1.5mm
gaskets available)
- 1 timiing belt
- 1 belt tensioner kit
- 14 custom made reinforced crank cap stud bolts and
nuts
- 3 M6 bolts
Now that I can believe.........$AU26,000 for an OS short motor that includes a full counterweight & big stroke crank with sleeves, deck plate and all the you-beaut internals.
I just can't see why someone would pay $30K for a block alone that can still pound a brg, crack a land, throw a rod, etc, etc!!
Yeah I noticed the gap was kinda big for our cars. Anyone up for a drive to the hills to help me change em for a 6pack o beers? :)
Feel free to bring the car down to Campbelltown though. i just got home from work and will be up for a bit. lol
what are your thoughts on this looks responsive enough and a little more balls than the 2871r just suggestion.
~GT2876r click me~
The GT2876R is a poor mismatch between the turbine and compressor. The 76mm compressor wheel is too big to be driven by the T28 ns111 turbine wheel.
This is highlighted on the Garrett website where they say;
* Not recommended for general performance applications
* Best suited for unique applications such as asymmetric turbo installations
Edited by D_Stirls
Hey mate,
I work in irrigation facing Currie street. I wouldn't be surprised if you didn't even know we existed, no one does!! lol. It has been decided that we have the better spot as we have windows facing the main road.. Let's just say, during uni and summer, awesome views!! lol
Anyway, the wheels...... What are you after for them? I have a mate that is a BBS fan boy who might be interested if I give it a miss. Can post pics if possible?
Cheers,
Peter.
Thought I'd move this post to Wasteland so Andrew, Joel or Matt don't smack us, lol.
Here's what they are.........haven't thought about price at this stage........265 x 35 x 18
Gap looks standard 1.1mm ?? should be 0.7-0.8mm i think mine are even 0.6mm i was planing on running large boost
FIXED
i wouldn't go any lower than 0.7mm, No need to and it effects your idle. Will bounce and pop at idle if any smaller.
It's amazing that the block costs that alone AND that Keir has blown 5! What is the exact difference in the OS block that makes it so awesome?
It is an engineering piece of art .... and people make serious power with them, that they just cannot make with a normal block
Nice find Steve - you do realise of course that it would cost you $10k+ to get it here including shipping, taxes and GST?!
Seems the price has come down somewhat .... mind you, it doesn't look like that is coming directly from OS Giken (with all of their associated knowledge and warranty that comes with it), so I guess it is from a cheaper distributor or something. Also sounds a bit fishy, since it says in 1 place 3lt (2996), but in other places it says 3.15lt. I guess that is a head gasket and piston stroke issue maybe.
Had a tinker around with the GTR last night and found that it still has the stock boost restrictor in one of the vacuum lines (Nissan put it in to meet the gentlemen's agreement and circled the line with a yellow stripe, etc etc etc).
Can't believe that none of the previous owners in Japan took it out to get a safe boost increase! Crazy.
parking in a loading zone that turns into a taxi zone at 6pm = fail, $79 fail
ahwell, my fault lol
parking on a main road at 11am that turns into a bike lane at 3pm. then get stuck doing shit when you thought you were only gonna be there a couple of hours and leave at 4:30pm = $148 fail!! :yucky:
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
