+1 to full of shit..
hey dan, cant wait for ya to get back... cruises.....
dale, first time i really looked at ur car last night... AWSOME! was good to have a chat with ya.. cant wait to c the future engine for the 180 ;)
cant wait to cruise!
Thanks Mate,
The New Engine, when i build it will be going in a complete new shell that will be properly preped (i.e. Seam Welded and half cage). But we are talking at least 18 month away.
Have the rebuild the CA and finish Our Dirt Circuit Car before I start that; but the parts collecting for it will start now.
Edited by D_Stirls
that WAS you i saw turning onto salis highway with that on the back ^^
those wheels are unreal, better in real life!
sure was mate, we seen ya down near waterloo cnr rd lights while at the servo
camber much?
hahaha that looks sweet,
cant wait to see the final product!
neither can i
my new 4 door shell will be its twin. basically everything we're doin to the gibson shell is what we're doin to my 4 door
oh, and with help i work fair quickly too ;)
Madaz.. Its most likely Pete's ISP blocking BigPong possibly due to high rate/poor reputation of spam/virus on bigpongs side. ;)
Fairly common for bigpong as they tend to have a lot of mums and dads where the dad goes in to pron picks up a virus has no firewall or virus scanner. The computer then starts spamming crap.
Multiple people do this in turn earns bigpong a bad rep. Bugger about it is bigpong are fairly slow getting on to their users and blocking them so it does them more harm than good.
Likely Pete's ISP is just over sensitive at the moment. So a bit of both.
i was using hotmail to which ive since changed my email addy as off 2 weeks ago from when i sent you spam
i also changed a setting the Internet Explorer security zone ;) then resent mail and didn't bounce
sent another reply Pete
sorry bud...........busy watching UFC on Fuel TV
I'm with Adam Internet and no one else is having issues sending me email.................now, back to UFC
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
