in response to $100 dolla bill thread which is better :D numbers dont lie bitches. taken from my orginal gtr special hpi mag. that decimal of a second means im like 1cm in front n stuff.
clearly my penis extension r32 is bigger and therefore better at compensating my lack of manhood than your 33s n 34s
Edited by Inline 6
i could also be agrued that they are progressively faster around a race track through the gen's as ive seen vids of the 33 and 34 smoking a 32 gtr around the race track. i believe alot of that is down to the attessa reprogramming making the newer more 4wd in the corners havin a lil more torque from the motor.
i got love for all of em but 32 will always be my fav, 34 is the best around a race track and 33 is the best value for money i think we can agree on.
and craig i dont diss peoples cars :) because after you drive a $300 dato for 7years its usually me on the recieving end of car disses. gives all a laugh though :P
if they made em smaller id want that 1 too :D 2 seater only 240z style would be crazy
Edited by Inline 6
aerodynamics, improved suspension design, improved chassis design, etc, would all play a fairly important part also. 32 had very little in the way of aerodynamic aids, 34 however...
lol Dan, I can show you figures that have the 34 GTR doing the 1/4 in 12's and 0-100kph in 4.5sec (stock standard)
they say vspec 2 32 can break into 12s aswell, they all just the reg gtr times hpi pulled.
alternatively sled you can pull your gtr out and line me up, its on mofo :banana:
*eye of the tiger beats playing in head
tempretures n tyres n such could play a factor in it when its that close, its a bees dick diff in there times. and i think a ztune should easily pull that sled :P
also note sled im an accountant(numbers obsessed) and i used to read every single magazine that spat out 1/4 mile times for skylines and como's (jus scouting the enemy boys) thats around about what they usually put them at.
^^ i thought u thought (get smart voice) i was dissing peoples cars, never mind all good dude my care factor is very low.
Edited by Inline 6
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
