in response to $100 dolla bill thread which is better :D numbers dont lie bitches. taken from my orginal gtr special hpi mag. that decimal of a second means im like 1cm in front n stuff.
clearly my penis extension r32 is bigger and therefore better at compensating my lack of manhood than your 33s n 34s
Edited by Inline 6
i could also be agrued that they are progressively faster around a race track through the gen's as ive seen vids of the 33 and 34 smoking a 32 gtr around the race track. i believe alot of that is down to the attessa reprogramming making the newer more 4wd in the corners havin a lil more torque from the motor.
i got love for all of em but 32 will always be my fav, 34 is the best around a race track and 33 is the best value for money i think we can agree on.
and craig i dont diss peoples cars :) because after you drive a $300 dato for 7years its usually me on the recieving end of car disses. gives all a laugh though :P
if they made em smaller id want that 1 too :D 2 seater only 240z style would be crazy
Edited by Inline 6
aerodynamics, improved suspension design, improved chassis design, etc, would all play a fairly important part also. 32 had very little in the way of aerodynamic aids, 34 however...
lol Dan, I can show you figures that have the 34 GTR doing the 1/4 in 12's and 0-100kph in 4.5sec (stock standard)
they say vspec 2 32 can break into 12s aswell, they all just the reg gtr times hpi pulled.
alternatively sled you can pull your gtr out and line me up, its on mofo :banana:
*eye of the tiger beats playing in head
tempretures n tyres n such could play a factor in it when its that close, its a bees dick diff in there times. and i think a ztune should easily pull that sled :P
also note sled im an accountant(numbers obsessed) and i used to read every single magazine that spat out 1/4 mile times for skylines and como's (jus scouting the enemy boys) thats around about what they usually put them at.
^^ i thought u thought (get smart voice) i was dissing peoples cars, never mind all good dude my care factor is very low.
Edited by Inline 6
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
