my mate is currantly doing his first year through MTA.
be prepared for $250 clear p/w
leaves me with enough money to live and drive , i dont really care right now , just want something id enjoy and when ever ive been working on cars with mates
its rewarding
Didn't want to hijack that chicks thread....but looks like Pete's taken me and a friend to our Grad dinner this thurs....
Was wondering if i should steal her idea of having a skyline fleet? :D
Guess its a bit late notice seeming as mine is THIS thursday....but still...if people are keen for a lil cruise from woodcroft to the city....then im all up for giving ya details on it lol.
Imagine the looks i'd get from people....a few skylines rockin up at the school. Theyd be like :D haha.
ill come along if you want me to :)
