Well just got back from a quick test run...
Took me a couple hours to fit the climate control's hot/cold door actuator and the rest of the interior I had to take out to get to it... mate of my soldered the dry joints last night...
and IT WORKS! Holy smeg! I haven't had a working climate control since I bought the car and I >finally< have airconditioning at my whim!
RAWR!!!
feel the power! revel in its awesomeness!
Thanks to madaz for showing me the tutorial link, I probably would have missed it otherwise. I owes you a brewski mon!
*sings a song about summer and climate controls while dancing a jig and drinking a beer*
-D
hey guys,
got my car today.. and it dies whenever i clutch in when it warms up..
its got apexi turbo, stock ecu, stock afm, bov blocked off, 3inch turbo back.
any ideas on wat would be causing it?
^ could start with like a process of elimination of things Adrian.
first thing that springs to my mind is get someone to make it stall the way it usually does while you watch from outside. If there's any black smoke coming from the exhaust it's simply too rich at idle/off throttle. If not, you've eliminated overfuelling to be the cause at least :D
Mine did the same Adrian when I used to clutch down to change into 2nd. Sif you never msg'd me to meet up somewhere so I can see the car.
sorry man i JUST finished work! catch up tomorrow night?
Hey was thinking bout going into town friday night or sat night as well!! Gouger street you say eh, might see if wifey's keen n head in!
im interested if others are, last time i went they had those cut out new lancers with forza 2 hooked up to the steering wheel n pedals n stuff schooled all the people around :D for free i might add.
plus ill be done with uni for the year and in need of alcohol :P
RAWR!!!
-D
thats awsome! im yet to own a car with air con :P
i'll let you fix mine up too :D
hey guys,
try unblocking your bov and run the standard one and see how you go?
Well, while we're being stupid, I'll run a pipe off the back of the turbo into the cabin, then I'll be too deaf to hear them complain :D
and be killed by the noxious fumes.
... win win really. :P
... win win really. :wub:
Yeah well I get that already when I only open the front windows, sucks in a lovely aroma of unburnt fuel (see my profile :laugh:)
But yeah I reckon thats a goer, I'll get on it tomorrow :D:P
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
