Anyone removed their rear seat, etc and re-registered their car as a 2 seater?
Edit: I know Richo did but I don't think he comes on here anymore.
You'll have to remove your seat belts as well and fill all the holes left by the removal of the belts and seats (this doesn't mean put the bolt back in it means fill them so they can be used again) and then you have to produce your car to regency for an inspection.
i bought some aluminium sheeting today and got creative.. still have to take it all off smooth edges and bends and give it a good clean... tonights task is aluminium brake ducts.. super sized :P
your a DIY genious Sir Jenksalot. make me one :P
hahah at this stage the aluminium is too thin for it to look pro... small dents and such.. if i find a thincker aluminium sheet id think about making them properly for people
Jenkies, where'd you get your pod filter cover from?!
just jap on the forums
anyone know wat injector latency i need to imput on my pfc for nismo 550cc injectors?
its for a rb25det..
cheers
p.s. wanna make me one too jenkies? ill pay u for it :laugh:
u could just make a copy of mine.. but as i said b4 the aluminium im using now is too thin... hows it all running ?? or i take it its not if ur mucking around with pfc? cant wait to see it
RIP ... Wendy Van Gasteren
http://www.news.com.au/adelaidenow/story/0...008-910,00.html
Killed 2 years ago today at O'Halloran Hill by motorcycle colliding with a pedestrian and then traffic behind not seeing her.
Was one of the best friends, neighbour, riding buddy you could ask for.
A tragic loss to the motorcycling community in Adelaide, who co-coordinated with me a few awareness programs. Not forgotten.
Ride safe, drive safe.
yeah very sad, I still remember the day it happened
lol, I'm coming over
Mark where's the best place to get a sheet from and how much?
need some help with something
i dont like my black intake plenum with paint chips , and i want to make it silver .
i can get it acid dipped cheap as my mate's dad owns a company that does all that stuff .
are there any precautions i need to take to ensure that it will still work/fit after being dipped ?
its 0.5 mm sheeting 900x900 from recollection $28 a sheet from stratco.... i wanna find 1 mm or 1.5 mm sheets of aliminium... the 0.5 is too thin, dents and looks a bit cheap and nasty but it still does the job.. sealing all my airbox with it atm.
http://www.samsung.com/au/consumer/detail/...cd=YP-S3JQB/XSA
Full Multimedia Device with Video, Music, FM Radio & FM Record, Photo & Text Viewer, Alarm, Clock, Games.
- 1.8” TFT LCD Screen (QCIF 176 x 220).
- DNSe2.0™ (Digital Natural Sound engine) Technology.
- Long Battery Life: 25 hours audio, 4 hours video playback.
- Light emitting touch pad controls.
- Supports MP3, WMA, MPEG4 (SVI), OGG, JPEG, TXT File Formats
Thats the link, if it works..
Its a 2GB version in white.
As for what id want for it, i dunno lol.
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
