Anyone removed their rear seat, etc and re-registered their car as a 2 seater?
Edit: I know Richo did but I don't think he comes on here anymore.
You'll have to remove your seat belts as well and fill all the holes left by the removal of the belts and seats (this doesn't mean put the bolt back in it means fill them so they can be used again) and then you have to produce your car to regency for an inspection.
i bought some aluminium sheeting today and got creative.. still have to take it all off smooth edges and bends and give it a good clean... tonights task is aluminium brake ducts.. super sized :P
your a DIY genious Sir Jenksalot. make me one :P
hahah at this stage the aluminium is too thin for it to look pro... small dents and such.. if i find a thincker aluminium sheet id think about making them properly for people
Jenkies, where'd you get your pod filter cover from?!
just jap on the forums
anyone know wat injector latency i need to imput on my pfc for nismo 550cc injectors?
its for a rb25det..
cheers
p.s. wanna make me one too jenkies? ill pay u for it :laugh:
u could just make a copy of mine.. but as i said b4 the aluminium im using now is too thin... hows it all running ?? or i take it its not if ur mucking around with pfc? cant wait to see it
RIP ... Wendy Van Gasteren
http://www.news.com.au/adelaidenow/story/0...008-910,00.html
Killed 2 years ago today at O'Halloran Hill by motorcycle colliding with a pedestrian and then traffic behind not seeing her.
Was one of the best friends, neighbour, riding buddy you could ask for.
A tragic loss to the motorcycling community in Adelaide, who co-coordinated with me a few awareness programs. Not forgotten.
Ride safe, drive safe.
yeah very sad, I still remember the day it happened
lol, I'm coming over
Mark where's the best place to get a sheet from and how much?
need some help with something
i dont like my black intake plenum with paint chips , and i want to make it silver .
i can get it acid dipped cheap as my mate's dad owns a company that does all that stuff .
are there any precautions i need to take to ensure that it will still work/fit after being dipped ?
its 0.5 mm sheeting 900x900 from recollection $28 a sheet from stratco.... i wanna find 1 mm or 1.5 mm sheets of aliminium... the 0.5 is too thin, dents and looks a bit cheap and nasty but it still does the job.. sealing all my airbox with it atm.
http://www.samsung.com/au/consumer/detail/...cd=YP-S3JQB/XSA
Full Multimedia Device with Video, Music, FM Radio & FM Record, Photo & Text Viewer, Alarm, Clock, Games.
- 1.8” TFT LCD Screen (QCIF 176 x 220).
- DNSe2.0™ (Digital Natural Sound engine) Technology.
- Long Battery Life: 25 hours audio, 4 hours video playback.
- Light emitting touch pad controls.
- Supports MP3, WMA, MPEG4 (SVI), OGG, JPEG, TXT File Formats
Thats the link, if it works..
Its a 2GB version in white.
As for what id want for it, i dunno lol.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
